Rattling camchain
Discussion in '6th Generation 2002-2013' started by popcorn, Jul 31, 2023.
  1. popcorn
    popcorn New Member
    Sweden
    Hi guys, I have a Honda VFR gen 6 from 2004 that I've owned since last year.
    I replaced the camchain-tensioners pretty much first thing I did as it has 46k miles on The clock.
    Things is, I'm a bit worried about this noise from the right side of the engine. To my ear it sounds like the chain is rattling quite a lot. I'm thinking this could be normal(ish) since the tensioners are working of the oil pressure rather than a springloaded tensioner but I'm still not convinced all is ok. I'm 50/50 that this is only my mind playing tricks on me but I would really appreciate any advice you guys could provide for me.
    I can hear it from both the front and rear cylinders wich points me away from a failing chain as one banks should be more noisy.
    What do you guys think? Thanks in advance!
    Video of the beauty running.
    https://youtube.com/shorts/nTMjj40wm_4?feature=share
  2. Grum
    Grum New Member
    Very nice looking 04.
    Sounds fine to me! Maybe you're just hearing a bit of clutch rattle, lower RH side.
  3. popcorn
    popcorn New Member
    Sweden
    Shouldnt that sound be affected when theclutch is engaged or disengaged?
    And thanks mate
