Ran across these today
Discussion in '1st & 2nd Generation 1983-1989' started by commrad, Mar 29, 2011.
  1. commrad
    commrad New Member
    Red Hill, GA
    SHIMS
    I know people use washers to shim the needle up on v4's, never saw actual shims before though.
  2. GreyVF750F
    GreyVF750F Member
    West of Cleveland Ohio
    Just regular washers from the hardware store. I use the same. The ones I use are .020 thick. The older carbs with grooves cut in to the needles and use a snap clip are .040 apart. So the .020 gives a little finer adjustment for A/F ratio. You can get 3 or 4, I forget, washers only before the twist lock won't fit.
