Radiator replacement
Discussion in 'Mechanics Garage' started by 99800, Apr 5, 2011.
  1. 99800
    99800 New Member
    Arizona
    Can i replace the ratiators on my 99 VFR 800 with a radiator from another model place it between the forks and engine instead of being on the side?
  2. Davis5g
    Davis5g New Member
    Pittsburgh, PA
    Is there something wrong with your radiators?
  3. NightViper19
    NightViper19 New Member
    Ohio
    I am not using the ones on my 2000 which will be a direct bolt on for you, and everything works. PM me if you wanna talk.
    Otherwise, I do not know about putting another radiator on the forks. Ive been told that this bike has cooling problems as it is with the two rads and a puller fan.
  4. JTC
    JTC New Member
    Watts, CA
    time and money can make just about anything happen:wink:
    99800 New Member
    Arizona
    No they are fine. I just dont like the way the bike looks when its naked with the radators on the side.
  6. Davis5g
    Davis5g New Member
    Pittsburgh, PA
    Oh, see I didn't know you had the bike naked. It would be ludicrous to try and front mount a rad with the fairings on. Buuutt, the side mounted radiators rely on the fairings to pull air through them and the bike tends to run hot without the fairings so front mounting a radiator would probably be a good project. Finding the right radiator and getting it mounted is going to have to be something you will have to spend a good bit of time on, as I don't know of anyone on here who as ever done it. Good luck with it.
  7. NightViper19
    Ohio
    Is this a bit too naked for you? :D
    Think it might look a bit odd, and you still gonna have a reservoir? The engine will be more exposed, and if its like mine, it looks ugly. Im thinking about pulling the rest of the frame and cleaning up the block and valve covers.
    99800 New Member
    Arizona
    I am keeping the reservoir but i am going to try and move it so that it is out of the way. As for the radiators i guess i am just going to have to do some trial and error.
  9. NightViper19
    Ohio
    Failing at something is best way to learn. Keep this updated, Im interested.
  10. matt1986vf500f
    matt1986vf500f New Member
    Lula, Georgia, United States
    HRC sold a kit for the RC51 that mounted the radiator in the front but t was expensive!
