radiator overflow tank alternate
Discussion in 'Mechanics Garage' started by Guest, Jan 31, 2003.
  1. Guest
    Guest Guest
    ???Greetings, having fitted the excellent HPS crash protectors on my '99 VFR 800, I'm now in search of an alternate (thinner/ smaller) overflow tank that will fit snug against the bike and not kick the side panel (valence?) out 3/4 to1 inches. Any suggestions? Cheers!
    Steve
  2. Guest
    Guest Guest
    Someone, somewhere on the 'net modified their coolant overflow tank for use with the frame sliders. They used a holesaw and cut away the tank where needed for the frameslider to pass thru the tank, then used some compatible plastic material to make a circular patch, then plastic-welded the whole works together.
    Dang if I can find the article now, I just searched for it. Sorry.
    Anyway, not sure how that fix worked out for the dude over the long haul. Maybe if you could get a used coolant tank and experiment with it??
  3. Guest
    Guest Guest
  4. Guest
    Guest Guest
    :) That looks like the ticket. I do like the looks of the moko sliders too. Thanks for the tip.
    Cheers!
    Steve
  5. proerj
    proerj New Member
    Silicon Valley, CA
    Steve:
    I installed the Moko frame sliders about a month ago. I bored out my radiator overflow tank to accomodate the slider like on the website mentioned before. It worked out pretty well. I like it because the slider mounts thru the frame into the engine block...Very stout. The only disadvantage, is that you need to remove the slider everytime you want to remove the side fairing, and of course, you need to drill a 2-1/8" hole in your fairing (very nerv racking).
    Cheers
    -eric
  6. CaptGarvin
    CaptGarvin New Member
    East Pole
    Where Moko
    Where did you find the Moko sliders for the 2002+ VFR.
