Radiator fan won't run on VF500
Discussion in 'Mechanics Garage' started by fosterfob, Jun 5, 2018.
  1. fosterfob
    fosterfob New Member
    Even when temps get high, the fan won't turn on.
    What are the common problems that cause this?
    on old bikes, it's very common for the thermoswitch to fail, so the fan won't come on. replace switch, but first test fan and wiring by touching the wire on switch to ground. if key is on, fan should spin.
    also, inspect fan fuse, and be sure cooling system is full.
  3. Terry Smith
    I'd suggest you physically check that the fan blade is not jammed e.g. by grass or a stone, and then check the fuse is intact. After that, you could check that you have 12V at the female spade connector on the thermoswitch (to ground) with ignition on; if not, there may be a broken wire or the fan connector block may be disconnected. You can connect a jumper wire to the female spade, to the chassis, that bypasses the thermoswitch and will make the fan run.
  4. fosterfob
    Thanks a lot. I will look into all those things
