R&G Frame Sliders not working?
Discussion in '3rd & 4th Generation 1990-1997' started by abrofsky, Sep 21, 2007.
  1. abrofsky
    abrofsky New Member
    I read an alarming post about R&G frame sliders not working on a pre '98 bike:
    "Those of you with R&G frame sliders or contemplating buying them will
    probably want to read this.
    About three weeks ago, my VFR fell victim to a member of the bump'n'run
    parking set here in DC. She ended up flat on her left side at 2 o'clock in
    the morning. As you may recall, if have the R&G sliders on the bike since
    last summer, (www.wilsonline.org/vfr/bobbins.htm) but this was their first
    "field test." Sadly, they failed miserably. :(
    I installed them according to the instructions. However, under the impact
    of the tipover, the bobbin became "impaled" on the spacer, causing the small
    end of the plastic bobbin to mushroom. The plastic slider was shoved toward
    the bike. The bike came to rest on the steel bar that ties the bobbin to
    the engine. In this position, sad to say, my middle fairing in now hosed,
    as the center part of the fairing buckled and cracked. Sorry, no pictures,
    as my digital cam fell victim to "kitty" this week.
    A drawing is probably clearer anyway. I've prepared an AutoCAD drawing
    outlining what happened, and the proposed fix. You need to insert a hefty
    washer between the sleeve inside the bobbin and the spacer. This spreads
    the load and keeps the bobbin from flaring. A washer slightly larger than
    the spacer should work great."
    Any comments on this guys?
