Quick question on rpms at 60mph....
Discussion in '6th Generation 2002-2013' started by Carolina06HondaRider, Sep 28, 2014.
  1. Carolina06HondaRider
    Carolina06HondaRider New Member
    For you guys with 2002-2009 VFR800s without drive line upgrades, what rpm are you turning at 60mph? Mine turns right about 4,000rpms. I'm thinking this might be high and that maybe my bike has a sprocket upgrade. I would like to know before I buy new chain and sprockets. Thanks for the help guys.
  2. MichaelD
    MichaelD New Member
    Central Kansas
    Stock sprocket sizes should be 16 front 43 rear.
  3. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    I've got a '99, but if anything, 4,000 rpm at 60 sounds low not high.
  4. gcarper
    gcarper New Member
    near Gaffney SC---40 miles from Blue Ridge Pkwy
    Recently installed new chain and sprockets [ stock sizes ] on my 05 model and rpm at 60mph [ gps ] is 4k
  5. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    Oops, looks like I was wrong. :confusion:
  6. ictghost
    ictghost New Member
    Kansas, the Land of OZ
    Just got back from a ride (stock 07, Gen 6). 4K at 60 mph, right on the money.
  7. Gweglez
    Gweglez New Member
    Southampton, United Kingdom
    I can confirm also, @ 70mph (National speed limit in the UK) it's just over 4.5k
  8. Mark919
    Mark919 New Member
    Detroit Suburbs
    Based on gearing calculations, using a standard 180/55 tire diameter of 24.9" and with std. 16F/43R sprockets, a gen 6 at 4000 RPM will be going 58.9 mph. So at 60 mph your RPM will be 4075.
    A gen 5 is geared differently and has 17F/43R sprockets. A gen 5 at 4000 RPM will be going 58.3 mph by calculation.
    Also for reference, a gen 6 with a deeper 45 tooth rear sprocket will be going 56.3 mph at 4000 RPM.
    I hope this helps.
