Quick one - Does 2001 VFR800Fi have O2 sensors
Discussion in '5th Generation 1998-2001' started by pap11y, Oct 4, 2010.
  1. pap11y
    pap11y New Member
    Sydney
    Hi guys,
    I was speaking to the powercommander dude and he said I should check if I actually have an o2 sensor. He said that I may not have one?
    I have a 2001 VFR.
    Anyone know if this has the o2 sensor?
  2. crustyrider
    crustyrider New Member
    North Country, New York
    yeah it should .its fuel injected....... you can tell by looking at the exhaust you will have two plugs (one on each collector after it goes from 4-2....)
  3. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    98 and 99 vfrs no o2 sensors...
    00 and 01 vfrs have o2 sensors...
    all sixth gens have o2 sensors...
  4. pap11y
    pap11y New Member
    Sydney
    I had a look yesterday and there are 2 plugs going into the exhaust.
    Does this mean I have 2 x o2 sensors? Or are they linked?
  5. crustyrider
    It means you have 2 ,,,,one on each side
    what I meant was not that all fuel injected bikes have 02 sensors...it is an emissions deal...sorry to mis lead all "california bikes have then.If they are new enough
  6. pap11y
    pap11y New Member
    Sydney
    Thanks everyone. I will order them. Though they will probably arrive before my power commander :(
    I am having serious ebay delivery delays...
    it hurts so bad...... :)
  7. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    then make your own o2 eliminators. 330 ohm resistors. there are plenty of threads on here pertaining to it...
  8. pap11y
    pap11y New Member
    Sydney
    I just picked up 2 x 330K 5% 1W carb resistor.
    MCAS do them for $90+ for 2
    UK do them for approx 50+delivery.. (and long wait :))
    I have the thread bookmarked so wish me luck.
    The resistor set was 45c
  9. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    its easy youll do fine
  10. Mark 024
    Mark 024 New Member
    Sydney, Aust
    Keen to hear how you go pap
  11. pap11y
    pap11y New Member
    Sydney
    Hi everyone,
    I installed the power commander last night. I used the "laser duotech exhaost with O2 sensors" map as it was the only non stock exhaust map with O2 sensors..
    Installing the powercommander was relatively straight forward:
    - there was no way I was getting the plugs behind my frame as there was no room. I threaded it up as best I could..
    I have only had a short ride but accelleration fron 1500-4000 is heaps better. Less jerky and much easier to ride at slower speeds.
    It is less lumpy and seems to be much more powerful.
    I used to change out of first and second quickly as it seemed to be labouring and sounded shit.
    Now I have a real first and second gear.
    O2 eliminators came with the power commander..
    Anyone know why I would manually adjust it? Does anyone actually do this?
    I was thinking I'd like a performance map and a city map so I can change between them..
    Does anyone with a power commander adjust them at all once they are setup?
  12. Meatloaf
    Meatloaf New Member
    Indianapolis, IN
    Some of us mess with the map but usually only when you know what you are doing. If you want a good map, then take your bike somewhere to have it dyno'd and tuned. They create a map specifically for your bike and it doesn't get any better than that.
  13. pap11y
    pap11y New Member
    Sydney
    Would there be any benefit in having a separate street and track map?
    One for economy and one for performance?
  14. Meatloaf
    Meatloaf New Member
    Indianapolis, IN
    most certainly. many of us do this. i have one for each. the zero map for the power commander seems to give me some of the best mileage but i also have one that was tuned which gives me more power for when i'm out having fun
  15. pap11y
    pap11y New Member
    Sydney
    Awesome. Thanks for the info Meatloaf.
    Hi-ho hi-ho its of to the dyno I go......
  16. pap11y
    pap11y New Member
    Sydney
    Yep a piece of. I didn't need to do it in the end but very straight forward (once you find the o2 eliminator plugs behind the coolant reservior)
  17. Mark 024
    Mark 024 New Member
    Sydney, Aust
    Hi Pap11y,
    did you get your bike dyno'ed?
    How did it go?
  18. pap11y
    pap11y New Member
    Sydney
    I don't see myslf getting to the dyno until dec unfortunately.
    Too many new enhancements for my bike and now its out of the budget (for now).
    I'll let you know..
  19. Mark 024
    Mark 024 New Member
    Sydney, Aust
    Yeah it adds up. Doing the stay upright course in Dec. Should be well worth it.
  20. pap11y
    pap11y New Member
    Sydney
    Yeah, I have dyno and suspension on the cards..
    Then track days.....
