Quick help please
Discussion in 'Mechanics Garage' started by goinphaster, Oct 18, 2007.
  1. goinphaster
    goinphaster New Member
    California
    I will have access to a torque wrench for the next 2 hours. can anyone tell me the torque specs for the rear wheel, front axle pinch bolts, front axle and caliper bolts. thanks a billion. I have the Files on the computer at home, and the computer I'm on will die if I try to downlaod something that big
  2. robg39
    robg39 New Member
    Aliso Viejo, CA
    Page 1-17 in Service Manual 2002-2006
    1. Rear Wheel Bolt: 12 FT/lbs
    2. Front Axle pinch bolts: 16 FT/lbs
    3. Front Axle: 43 FT/lbs
    4. Caliper Bolts: 14 FT/lbs
  3. goinphaster
    California
    My hero!:first: even thought to specify year since I didn't:brick:
  4. robg39
    robg39 New Member
    Aliso Viejo, CA
    Glad I could help. Good luck with the repairs!!
    Rob
  5. goinphaster
    California
    No repairs, just got some of them new super sticky michelin pilot road 2's, and need to retorque everything back on. hopefully they last more than 8,000 miles like the original tires did. I do think they are really sticky, my rear tire never moved around the bed of my truck during it's 50 mile trip home:ballchain:
  6. squirrelman
    them rear wheel bolts are thick, and 12ft-lbs really doesn't sound like enough.......is it, really???
  7. mello dude
    Off the top of my head - I think the rear wheel lug nuts = 83 ft-lbs, 14 on calipers bolts seems a bit shy.
    - A Q for everybody - my '98 manual says 52 ft-lbs on the axle bearing pinch bolt. I felt that was too much so I checked an old 4th gen manual for comparison and it say 40 ft-lbs. What the 6th gen manual say?
    - BTW on the 5th, I almost went to torque spec and felt it was near stripping so I backed it off.
  8. reg71
    Sikeston, MO
    On mine, I usually just go to PFT then recheck it after a the first couple rides. I have a torque wrench, but I think I've only actually used it once on the pincher. I use it on the smaller stuff that I'm afraid of breakin...
  9. squirrelman
    IMhumbleO....83 can't be right for those rear wheel bolts either..that's gotta be too much??
    just totally guessing (don't have manual), based upon size, i'd GUESS that about 40-45ft-lbs would be ok.
    anyone who actually knows please respond!
  10. DANIMAL
    DANIMAL New Member
    Metairie, LA USA
    rear wheel bolts torque
    Honda's Factory manual states torque is 80 Ft-Lbs
  11. derstuka
    San Diego, CA
    I do the same thing reg...if PFT is what I think you mean...same with car lug nuts. Big lugs I use the PFT method. Never had a problem.
  12. squirrelman
    so i guessed wrong?? well i was busy reading the Bible, not shop manual!!
    And praying that my voltage regulator remains in good health.
  13. mello dude
    PFT? ok I give.. fill me in:confused:
    MD
  14. derstuka
    San Diego, CA
    I believe that he means "pretty f**king tight!" hahaha!
  15. mello dude
    OOOOhhhhhh!:smile: :smile: Warning - occasional brain fart......:dizzy: :laugh:
    MD
  16. nozzle
    nozzle New Member
    Southern Maryland
    FYI... you can get a good enough for most stuff torque wrench for less than $20 from places like harbor frieght. sSeems like a good thing for your Christmas List. if you don't have one yet.
  17. reg71
    Sikeston, MO
    you know I actually have a torque wrench now. I have just been doing it without for so long, I just don't usually think of it unless it's something that I think needs to be precise.
