Quick 6th Gen spec help
Discussion in 'Mechanics Garage' started by BMWHO, Aug 20, 2010.
  1. BMWHO
    BMWHO New Member
    Milliways
    My mechanic is travelling in tomorrow to help me put new shoes on the bike.
    He asked if I knew what sizes of wrenches he should bring to remove/reinstall the front and rear wheels.
    I have a manual at home, but will not access it until after he hits the road.
    I assume the rear will come off with the 4 lug nuts removed. Size?
    I probably have that socket though.
    The front axle nuts are the big question. What size are they?
    Also, is there any other hardware to remove for the front or rear wheels to come off?
    Thanks.
    T
  2. stoshmonster
    stoshmonster New Member
    Torque Specs. Rear wheel lug nuts 108Nm-Approximately 80 ft/lbs.
    Front axle bolt 59Nm-Approximately 45 ft/lbs.
    Front axle pinch bolts 22Nm-Approximately 17 ft/lbs.
    Front brake caliper mount bolts 31Nm-Approximately 23 ft/lbs.
    Hope this helps you.
  3. Metallican525
    Metallican525 New Member
    Rockville, Maryland
    Stock bolts on the right side caliper and the axle pinch bolts are 12mm
