Questions about 2003 VFR800 and ABS brakes
Discussion in '6th Generation 2002-2013' started by Parker VFR, Jun 4, 2013.
  1. Parker VFR
    Parker VFR New Member
    I have a 2007 with ABS, and the caliper is gold. Is that true for a 2003 with ABS? My friend is looking at a 2003 with ABS, and the caliper is not gold, so how do you tell if it really has ABS?
  2. Jagred
    Jagred New Member
    Tuscaloosa, AL
    On the instrument panel, mine has a light (in the row of dumby lights near the FI light) that says "ABS"
  3. Parker VFR
    Okay thanks. I'll pass the info along to my friend.
  4. TOE CUTTER
    Pulse ring is a dead give away as well.
  5. Scubalong
    +1 What he said
  6. Rollin_Again
    Rollin_Again Member
    Duluth, GA
    The ABS model also has a remote adjustment knob for the rear suspension just above the right rear footpeg. The non-abs model does NOT have this.
    Rollin
  7. OOTV
    OOTV Member
    The remote adjustment knob is not a true give away, I actually put a Jamie Daugherty modified ABS shock on my bike and it does not have ABS, but for the most part Rollin's statement is typically true.
  8. Scubalong
    Now the OP really confuse :potstir:
