Question about Injector connection numbers.
Discussion in 'Mechanics Garage' started by Fantastic!, Sep 17, 2013.
  1. Fantastic!
    Fantastic! New Member
    I was doing a throttlebody sync and I had to remove the injector connections and discovered that the injector for #4 and #3 were on the wrong cylinders. E.g #3 was connected to cylinder #4's injector and vice versa. I put then on the proper number cylinders but I am wondering if this is a critical issue even? Shouldn't the bike have just not run?
  2. TOE CUTTER
    Injection timing does matter, can mix them up in any order.
  3. Fantastic!
    Going to assume you meant doesn't.
  4. signal
    I found this today myself. #3 and #4 injectors were reversed. So I take it, it doesn't matter? There is no consequence to this?
