Question about Brake light
Discussion in 'Mechanics Garage' started by DA5alive, Mar 19, 2009.
  1. DA5alive
    DA5alive New Member
    Atlanta, Ga
    If anyone might have a clue why my brake light is stuck on.... Is there a relay switch on it that could be stuck? Changing the bulb did not work of course.. just wondering if someone might have encountered the same problem.
  2. Slothrop
    Slothrop New Member
    northern lower Michigan
    Did you adjust your rear brake pedal recently? There's an adjuster there for the light switch, to get it to come on at the right point.
  3. DA5alive
    DA5alive New Member
    Atlanta, Ga
    Haven't adjusted it, but I will check that out, Thanks
  4. squirrelman
    screw the adjustment ring counterclockwise about 1/2 turn;i f that doesnt fix it remove the switch and work some oil into it.....
  5. masonv45
    masonv45 New Member
    It should look similar to this:
  6. CARMINE
    CARMINE New Member
    Italy
    (NAPLES) ITALY
    Hi,
    I had the same problem just last week : A lubricating spray is the solution !
    Ciao, Carmine
