Q about bearing pullers
Discussion in '1st & 2nd Generation 1983-1989' started by Dukiedook, Jun 26, 2010.
  1. Dukiedook
    Dukiedook New Member
    Kansas City, USA
    Hey guys,
    I was planning on powdercoating my rear wheel on VFR#2 and figured it would be a good idea to pull the bearings and get some new ones put in.
    I saw I could purchase most of the Honda tools from lawnmowerpros.com but each piece is about $20US (Yeouch). Would something like the Motion pro bearing puller set be up to snuff for pulling and putting them back in? Or if you know of other reasonable priced sets out there let me know.
    Any help is appreciated
    Ryan
  2. TOE CUTTER
    I have never used anything but a hammer and a long punch, no need to show them any love if they are being replaced.
  3. Dukiedook
    Kansas City, USA
    Oh, even for driving them in?
    I figured you would want something sized specific but I guess as long as the pilot is as big as the bearing I guess that would be OK.
  4. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    For what it would cost you to buy the necessary tools to remove and replace the bearings, you can buy all new parts. Which is the best thing to do anyway. When reassembling put the bearings in the freezer and the wheel in the hot sun, then the bearing will go in fairly easily. Make sure the driver is the same size as the outer race of the bearing and just a bit smaller than the ID of the wheel opening.
  5. Lgn001
    Lgn001 Member
    Russian River by Ocean, CA
    You can always use the old wheel bearing to drive the new one in (if necessary). As long as you keep the new one square in the bore and tap on the outer race only, there generally is never a problem.
  6. Mobtown
    Mobtown New Member
    Baltimore, MD
    Harbor Freight (or your equivalent) for the win
  7. GreyVF750F
    GreyVF750F Member
    West of Cleveland Ohio
    ++1 on that. A large 1/2 drive socket also works. If you don't have a socket big enough then use the old bearing with any big socket on top. Doesn't matter how the socket fits on the old bearing cause your not going to use it again.
