Put a stroker in my vfr700
Discussion in 'Mechanics Garage' started by camo, May 10, 2011.
  1. camo
    camo New Member
    The Heartland
    I have had my 86 vfr700 for the past 6 weeks. I bought it cheap and put some effort into making it look and run better. I redid the bodywork, fork seals, regulator. Once I put quieter mufflers on it I realized that the motor was not up to spec. It made some mechanical noise that was covered up with the loud pipes. I checked the compression, Testing the rear bank I had 50 and 70 psi. My bike had been through numerous owners with varying degrees of mechanical skill.
    I had debated selling it but found a fresher 1986 vfr750 motor on vfrworld from BradMcDill. I just got the motor installed on Sunday. The motor was a straight bolt on (both have brown side covers).
    I am using my own carbs, ignition box and exhaust system. I haven't ridden it since the transplant yet but started it and was the throttle response so much sharper and the mechanical noise is gone. Maybe tonight I can get it on the road again.
    Thanks Brad for the motor.
    So my motorcycle engine has a 3 mm stroke increase. should give a nice increase in torque.
  2. Dukiedook
    Dukiedook New Member
    Kansas City, USA
    Or an extra scooter! Enjoy the extra hp!
  3. crustyrider
    crustyrider New Member
    North Country, New York
    um yeah the mechanical noise went away....you changed engines........
  4. camo
    camo New Member
    The Heartland
    I took it out on the blacktop tonight. Nice, makes me feel much better about the bike. A good way to start my 36th year of motorcycling and my 60th year.
    Very observant crusty rider,
