Pulse Generator Confusion
Discussion in 'Mechanics Garage' started by Hingley, May 6, 2020.
  1. Hingley
    Hingley New Member
    Hi Guys, I have a 1990 VFR750 that just does not seem to run right so I started checking the ignition system.
    based on my very limited knowledge of electrical the coils, wires and plug caps are within factory specs.
    When I went to the pulse generator that is when the fun starts.
    In the manual it says the ( PG ) Pulse Generator should be warm ( around 70 f ). On the 1990 the test is to check the ohms between the white/yellow and yellow wires as well as the yellow and white/blue wires.
    When I did this I got 298 ohms between the white/yellow and yellow wires and nothing between the yellow and white/blue wires. In the manual it says I should have read some where's between 200 and 400 ohms on both sides.
    Did I screw up somewhere?
    Does this all sound right?
    Does anyone know which wires relate to which plugs? I ask this because if I was to guess the spark at cyl #3 looked weak last fall before storage
    Thanks from co-19 land and tragic loss in Nova Scotia
