Problems
Discussion in '1st & 2nd Generation 1983-1989' started by Grade247, Mar 23, 2011.
  1. Grade247
    Grade247 New Member
    So i FINALLY got my exhaust back on the bike minus the slipons (they arent fittin like the stock pipe) and found out one of my carbs is leaking fuel (awesome!) and this may sound really dumb and I was having a brain fart but I cant find where to plug the fuel sender from the gas tank onto the bike (FTMFL)
    but other than all that is only took about 5 seconds of full choke and cranking to get it started and idle great it has been with out a gas tank all winter.
  2. rpierce
    rpierce New Member
    Dayton, Ohio
    Fuel sender should be a red plug. It plugs in right under the front of the seat if it's taken off. Should be a big rubber/plastic collar above the fuel pump covering 2 plugs (sometimes it covers the red plug and you cant see it).
  3. Grade247
    Grade247 New Member
    haha I know EXACTLY what you are talking about and thank you a million times I would have wasted prob another hour(s) lookin for it again. If I am ever down in your neck of the woods I owe you a drink my friend thanks again
