power question
Discussion in '6th Generation 2002-2013' started by Guest, May 16, 2005.
  1. Guest
    Guest Guest
    I have two questions about the power of an '04 VFR. For one, if I were to get one, what kind of top speed can I expect stock? I'm no speed freak, but I love to wheelie, which brings me to my next question. I had a '99 VFR(loved it)and I could power wheelie easily in 1st and 2nd. Can I expect to be able to do this on an '04??? Any input would be appreciated..... :)
  2. Guest
    Guest Guest
    I had a 99 viffer and now have a 04 viffer. I have had the 04 going a buck 45 so the top end is there. Wheelies are a little trickie with the vtec. You have to bring it to past 7 grand on the tach to get all valves running then crack the throttle. A little more trickie then the 99 but very do able. I definitely like the 04 much better all around. Seems to be a more refined bike
  3. Guest
    Guest Guest
    Not a great bike to wheelie, as it's heavy as hell, not very powerful, and if you do make a mistake, it doesn't crash well. Can't fit crash bungs due to the side mounted radiators, which are pretty fragile, and expensive, $350 a pop. I got into some gravel, and went down on mine, with the saddle bags on, and did $3500 in damage (that's parts only), without a scratch on my body. Keep it sunny side up!!
  4. CaseyTram
    CaseyTram New Member
    top speed
    I have an '02 with USB power commander, K&N air filter, and o2 sensor elimenators. Top speed of 152mph.
  5. desonier
    desonier New Member
    Top Speeds VFR03
    The VFR800 2003 non/ABS quotes a top speed of 165mph. It can and has been done. :)
  6. ZonaMan
    ZonaMan New Member
    Tucson
    You may want to get a more "sport" oriented bike if you want to do tricks and show off your mad skills!! LOL
  7. R.W.
    R.W. New Member
    Cloverdale CA.
    Power wheelie in 2nd? :confused:
