Power commander with auto tune
Discussion in 'General VFR Discussions' started by Vfryellow, Sep 24, 2013.
  1. Vfryellow
    Vfryellow New Member
    Indianapolis, Indiana, United States
    Just installed my power commander 5 with autotune. 07 vfr. are you guys using the accle pump and what are you all using as a afr setting. right now i started with the base map pc offers and afr starts at 13.2 and goes up to about 13.7.
  2. Vfryellow
    20130925_012429.jpg also for the ones thinking about this mod, the o2 sensor fits in the factory o2 sensor hole and i used the plug that comes with it to remove the 2nd o2 and plug hole. lol looks much cleaner.
  3. signal
    I am not using the Accel Pump feature of my PCV. Did you end up setting it, if so what do you think of it?
