power commander v maps where to find?
Discussion in '6th Generation 2002-2013' started by 83 interceptor, Jul 14, 2013.
  1. 83 interceptor
    83 interceptor New Member
    i have a 2004 vfr800 with a 2006 motor in it. pair and flapper mod and gutted exhaust and k@n air filter and o2 delete. where do i find custom maps for this. i have the power commander five and am looking for a map
  2. Dead Eye Dick AKA Carpy
    Dead Eye Dick AKA Carpy New Member
    Chill Out City
  3. 83 interceptor
    i was looking for one with stock gutted mufflers with cat o2 delete pair and flapper mod and k@n filter
  4. 83 interceptor
    also whats the diffrence between 2004 and 2006 motors?
  5. 83 interceptor
    any help?
  6. OOTV
    OOTV Member
    I believe the VTEC engagement RPM is different on the two models 6800RPM vs. 6400RPM ('04/'06). As far as "custom" maps, on the "other" VFR site there are downloads to members uploaded maps, that may or may not suit your setup, the best way to get what you're after is have it dyno tuned my a mechanic (~$250-$300). I hope this helps.
  7. ZEN biker
    ZEN biker New Member
    Assiniboia, SK
    Gutted exhaust (o2 delete is required for the pc to work without the ecu fucking it up) and a k&n filter. The flapper and pair mods dont change your fueling and timing requirements enough to worry about. There are plenty of maps that would work for you. But as ootv said, if you want the best you can get. Get it tuned for your bike. No two engines are the same, no exhaust or intake filter is the same for that matter.
  8. jethro911
    jethro911 Member
    Merrickville, Ontario Canada
    You could always buy the autotune module and just let it do the work for you. I have one and it seems to do the trick pretty well.
