posi-locks ???
Discussion in 'General VFR Discussions' started by volmann, Nov 27, 2015.
  1. volmann
    volmann New Member
    Johnson City TN
    What size posi-locks do i need for the 3 yellow stator wires ...to bypass the plug
  2. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
    I would just solder and heat shrink them to be honest.
    Any connector is a point of failure.
  3. volmann
    volmann New Member
    Johnson City TN
    I dont solder good...messy at it
  4. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
    Do you have any friends that are decent? Personally, I don't like crimped type connections since they can oxidize and/or come apart more easily.
    Shit, if I lived in the US I'd tell you to send me your stator and R/R and I'd solder them for you. LOL.
    Check the wire size (can't remember the gauge but I believe you want the Yellow ones - verify by looking at the wire it should be marked down the side of it): http://www.posi-products.com/lock2.html
  5. NormK
    NormK New Member
    Solder them, no time like the present to learn how to solder them, save you a lot of grief in the future. Get a soldering iron, get some old wire to practice on, strip the wire back 5mm, clean it with steel wool till it is shiney, twist the wires back tight, hot soldering iron onto the wire and bring the solder up onto the wire, get the wire coated with solder. Do the same to another piece, then bring the 2 soldered ends together side by side, hold steady and with the iron melt the soldered ends together.
  6. rjgti
    rjgti New Member
    regina sk
    just twist dem together and tape them :)
  7. NormK
    NormK New Member
    Twisting them together and taping them is not a good fix, they get hot and the tape melts:sorrow:
  8. rjgti
    rjgti New Member
    regina sk
    hehehe thanks for catching that norm
  9. ridervfr
    Belgium
    gawd. When you coat the wire with solder, its called "tinning" don't use wire nuts or tape, like they said above practice makes perfect, and some good magnifiers work well.
  10. rjgti
    rjgti New Member
    regina sk
    use a torch to make it neat
  11. CatHerder
    CatHerder New Member
    Michigan
    Slide the heat shrink tubing on first
  12. richieg66
    richieg66 New Member
    Twist together, solder and then cover with heat shrink. Permanent fix.
