poor running when hot
Discussion in 'Mechanics Garage' started by milo, Apr 30, 2006.
  1. milo
    milo New Member
    gt yarmouth norfolk
    i have been having some problems with my bike when the temperature gets to the piont were the fans cut in.
    ie sitting in traffic.
    the bike would loose power to the point were i had to keep blipping the throttle to keep it going,and pulling away was very jerky till you got moving.
    just add i have scorpion race cans on.
    i went to see may dealer and the mechanic siad the try changing over the wirs to the lamda probs,this had worked before and evans the running out.
    i have change them and it seems to have worked and it do,s feel better.
    the lambda wire conections are behind the left hand side near the radiater hoses,there is a white and black plug (there are very fine wires at the top so be carefull).
    the lambda probs check the emissions in the exhausts and change the fuel when needed,so it is possible my cans were up setting the balance.
