please help my bike run better
Discussion in '1st & 2nd Generation 1983-1989' started by tothesummit, Aug 3, 2013.
  1. tothesummit
    tothesummit New Member
    my 85 vf500 has had the carbs cleaned spotless.. floats set to factory .. new glass lines .new plugs.. carbs synced.. timing checked.. compression tested.. so my problem is cylinders1 and 3 dont seem to be doing anything.. bike is running very rich.. plugs from 1 and 3 r coming out black.. bike barely runs.. then paid to have carbs cleaned and still the same issue.. any insight to my problem would be great..
  2. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    no spark? bad coils?
  3. tothesummit
    Coil and plugs tested. There good
  4. Rollin_Again
    Rollin_Again Member
    Duluth, GA
    Are the plugs wet?
    Rollin
  5. tothesummit
    yes plugs 1 and 3 are coming out wet.. i nvr changed float needles wonder if thats the problem but its just kinda wierd that its cylinder1 and 3
  6. 4a15
    4a15 New Member
    Cincinnati
    BAM! You found the problem. The needle seats harden after a quarter of a century. Does not matter where u set the float, if the needles don't seal, its going to run rich. And the best part is when u fill up your cylinders with fuel, then try and start it!
    Replace the needles.
  7. squirrelman
    Could be bad CDI; that bike has 2, each firing 2 cylinders. Without an adequate spark to burn the fuel, plugs will look wet.
