picture of inside my carbs, i need clarification please
Discussion in '1st & 2nd Generation 1983-1989' started by moose122000, Jun 27, 2014.
  1. moose122000
    moose122000 New Member
    IMG_20140627_192950.jpg , so if i read the book right....the tube to the right is the starter jet and can be removed as stated in the cyler manual page 211 figure 21 item b.
    If that's correct......all 4 are not coming out....any suggestions
    Thanks in advance
    Scott
  2. ridervfr
    Belgium
    You don't need to remove this, its a pressed in piece. Best you can do is pass some wire through it and use carb-cleaner and air. Thats it! Get a proper manual, clymers sux btw.
  3. moose122000
    Thanks, will do
  4. squirrelman
    Like he ^^^ sez, don't attempt to remove. If you can blow air through the tube and hear it emerge from the choke plunger hole, tube is clear and AOK.
  5. moose122000
    The tubes are plugged solid. No air or cleaner getting through...i was thinking of using a very tiny drill bit to chew through the gunk but unfortunately i am not sure if it is a straight run, so for now i keep soaking in cleaner and try to push through with a wire....
    Thanks for the response Squirrelman
  6. squirrelman
    I/t IS a straight run. Try the drill if soaking or wire doesn't clear them.
  7. moose122000
    BBQing steaks right now, I'll drill it out after supper. :)
  8. moose122000
    Drilled out the gunk, cleaned and now rebuilding the carbs...will update and hopefulyy it starts tonight.
  9. ridervfr
    Belgium
    gee, hopefully its a happy ending, run it up to red line when it warms up and give us a full report.
  10. kennybobby
    kennybobby New Member
    what size is your drill bit and how far did you stick it in? An electric guitar string, e.g. 15, should push through almost 2 inches if it is cleared out.
  11. moose122000
    The drill bit was extremely tiny, wire really didnt have any effect. The bit only drilled a very small distance...best guess a mm...or less...afterwards the wire went right through without any problems as well as the cleaner/spray.
