Picked up an 87 VFR700 But....
Discussion in '1st & 2nd Generation 1983-1989' started by mpadgett88, Dec 5, 2012.
  1. mpadgett88
    mpadgett88 New Member
    medford, oregon
    but I noticed its not starting anymore very good when it does start its realy hard to start and its idle is rough.
    Perhaps the carbs should be cleaned. I havent owned a bike in so many years I am a noob all over again. what should I do with this bike??:chaingun:
  2. TOE CUTTER
    Got any history on this beast?
  3. squirrelman
    First, drain and clean the fuel tank. Next, check battery voltage and recharge if less than about 12.5 volts, then check charging voltage at 5000 rpm. Look for a fat blue spark on all 4 plugs while the engine is cranking over on the starter.
    Your carbs probably do need cleaning, but verify sparks first.:hss::redface:
  4. mpadgett88
    medford, oregon
    no history really. 61k on the odo looks dirty like it hasnt been servoced
    in a while. thanks for the advice squirrelman. you have a good rep
    i have seen. ive never done work on my own bikes. but i like to
    see this project turn into something awesome.
    ive noticed it lacks power i think the carbs deff need a cleaning
    maybe a rebuild. any clue where to find a kit?
    also when i come to a stop sign it will shut off unless i rev it up
    id add pics but not sure how from my phone. forumspport tapatalk?
  5. mpadgett88
    medford, oregon
    gets worse now. trying to start it up the starter went out I think. just goes click click click. not to mention the battery drains super quick. think i got fucked on this bike.
  6. wagzhp
    wagzhp New Member
    Sacramento area, CA
    Are you sure the battery doesn't just need to be charged, or replaced? If you have jumper cables, try jump starting it from a car, but make sure the car is not running. (I hear that would provide too much current)
  7. mpadgett88
    medford, oregon
    yeah turns out the battery is dead now. i tried to push start it too much failed every time.
    would a bad batter effect idle and possiblly cuase the bike to shut off?
  8. mpadgett88
    medford, oregon
    kudos. i feel stupid :) lol
  9. TOE CUTTER
    You need to do as Squirrel suggested aboot the charging system, low system voltage will cause the bike to idle poorly and want to die.
  10. mpadgett88
    medford, oregon
    and i can check that using a multi meter testing where on the bike?
  11. squirrelman
    Between the two battery terminals, namely the Positive (+) and the Negative (-), easy enough ?? One on the left, the other at the battery's right side after you remove the seat of course.
  12. mpadgett88
    medford, oregon
    I know that part but should I be checking relays? the bike will not start and I have it now on a trickle charge.
    I am a real noob to this kind of bikes so bare with me on my ignorance.
  13. squirrelman
    IMO no rinky-dinky milliamp trickle charger will rechagarge your dead battery proppaly. Instead, you need between 1 and 2 amps of charging power for between 8-10 hours.
    Things most riders don't know with their first bike: you need to have a 1 amp battery charger, accurate tire gauge, powered air pump for the tires, multimeter, tools. Motorcycle ownership without these essentials won't be easy.
    Factory service manual is mandatoy reading.
  14. mpadgett88
    medford, oregon
    good thing I have all that. and my charger goes up to 6a i just dont want to set it too high what would be a safe setting?
  15. mpadgett88
    medford, oregon
    *Update*
    I put it on the charger till it said charged started it up with choke let it warm up for a few mins slowly put the choke down, sprayed some seafoam carb cleaner in the intake and gas tank. and ran the shit out of that old gas. and it ran good its cold her so if the choke is too low it dies. so next I plan to check all the choke lines/ vacuum lines and clean the carbs out really good and I assume it should be running good. I still plan to check the charging system and battery as I believe the battery is bad since its so old and drains so quickly. would have done it tonight but I found my multimeter chewed by my dog haha. thanks Squirrelman your advice was ideal. You and Toecutter have trully earned your titles as Guru's. :):chaingun:
  16. mpadgett88
    medford, oregon
    These machines sure are cold blooded pigs way worse than my R1 may she rest in peace
  17. mpadgett88
    medford, oregon
    Another things I was wondering about. I heard theres something different about cali bikes? whats the deal with that
  18. Maggot
    Maggot New Member
    Park Ridge, IL
    I can't help you about '87 Cali bikes. But I'm sure someone here will be able to explain.
    Go to Yuasa Batteries, Inc. and click on "Tech Manual". It is about 25 pages on everything you ever wanted to know about batteries. This will teach you what to do about checking and charging your battery.
    Take your time with this bike, it will be worth every minute! Don't worry about asking questions. We all have to learn somewhere and all the goofy people on this forum love to help and want to see you succeed!
  19. TOE CUTTER
    California bikes have a bit of crap caked on them, you have a set of metal lines from the front head that run to a Kunooter valve assembly, some vacuum lines and a charcoal canister....AKA California emissions. It is best to remove it in my opinion because the age of the vacuum lines. Most I have worked on have had cracked lines due to age and heat. You can pretty much remove and pitch all in the trash can and cap off the tubes where they go into the head, cap 5 small ports on the carbs, cap 1 large port on the air box, route small vent line from front of tank down to bottom of bike with battery and over flow lines, and where the float bowl vent was hooked up to that goofy little control valve just unplug and leave open to atmosphere. Aboot a 2 beer job. When you get this bike sorted oot it should not be cold blooded at all.
  20. TOE CUTTER
