Peak voltage adapter recommendation?
Discussion in 'Mechanics Garage' started by signal, Oct 7, 2013.
  1. signal
    Can someone recommend a peak voltage adapter? I have a meter that can do min/max, but after reading up on this, it doesn't seem that is sufficient to measure peak voltage applications on motorcycles.
    So I want to purchase an adapter, I am looking at this one from CDI:
    CDI DVA Adapter: 511-9773NL
    they also sell it with leads, but I don't need those:
    CDI DVA Adapter and Test Leads: 511-9773
    I just want to buy something decent that will work. Just want to measure things like my CXP sensor, etc.
  2. danny_tb
    danny_tb New Member
    Melbourne
    You could try using an old oscilloscope, or a USB oscilloscope.
  3. rjgti
    rjgti New Member
    regina sk
    i would scope it myself or use a spectrem analyser
  4. signal
    I am not sure I understand the oscope and spectrum analyzer recommendations. I am talking about just checking peak voltage. An adapter is maybe $50, it will store the instantaneous peak voltage from the CMP or CKP sensors and allow me to read it via a DC meter.
    I have seen some ultra portable scopes go for $150 or so used, and spectrum analyzers just seem like $$$$...........
    If I should be using one of these devices can someone just give me a little background on why to use that vs. just a peak voltage adapter? I could potentially spring for a $100-150 portable o-scope thing, but all I am trying to do is eliminate my CKP as being faulty as per the manual.
  5. rjgti
    rjgti New Member
    regina sk
    just use your dmm and adapter if that is what you have:biggrin:
  6. danny_tb
    danny_tb New Member
    Melbourne
    The scope suggestion was just in case you or a friend has one laying around somewhere (or if you can find an old one for $20 on ebay that works).
  7. rjgti
    rjgti New Member
    regina sk
    A scope will show you supeefilis transit spikes
