PCV on a 6th Gen?
Discussion in 'Mechanics Garage' started by winaje, Sep 17, 2009.
  1. winaje
    winaje New Member
    Melbourne, Australia
    Hi all. I see a PCIII USB available on the PC site, but not a PCV. Does a V fit?
    Thanks?
  2. SwiftTech
    SwiftTech New Member
    San Jose, CA
    Look at the ones for the 2009 model year VFR. THey have the PCV listed there. Seeing as honda didn't actually change anything for the '09 model year you can use the PCV on any 6th gen.
    Also see this: PCV on 6th Gen
  3. winaje
    winaje New Member
    Thanks for the reply Swiftech. I should have said that I have an '05 model, which I believe has different connectors to an '09...
    Also, the link you posted doesn't work...
  4. SwiftTech
    San Jose, CA
    There I fixed the link. I do not think the connectors are different between the 05 and the 06. Honda did change the mapping a bit on the ECU for '06, but I'm pretty sure the hardware is the same. I do not have access to any other bikes though to confirm. Best of luck anyway!
  5. SwiftTech
    San Jose, CA
    This from coderighter over on VFRD. You should be fine getting the PCV for an '09.
    Cheers.
  6. winaje
    winaje New Member
    Thanks again for the replies. I've saved the links to that thread and also the 3000 mile report on the results...
  7. SwiftTech
    San Jose, CA
    Glad I could help. Let us know if you get one and how you like it.
  8. jetdoc
    jetdoc New Member
    ihave an 07 and installed a pc v. It works just fine. Actually the box says it's for an 09, but the guys at fuel moto USA say there is no difference between the 06-09. It works great. Jamie at fuel moto will give you the best price, and will load whatever map you desire, so it's plug and play. Easy to install.
    Cheers
    John.
  9. coderighter
    coderighter New Member
