PCIII Map for Stock Bike
Discussion in '6th Generation 2002-2013' started by boostin1989, Jun 8, 2009.
  1. boostin1989
    boostin1989 New Member
    I know this has been discussed before but I can't seem to find anything from searching. I just got a PCIII and O2 eliminators for my '02 and installed the map from Dynojet for a stock bike. It runs WAY better, however I think it lost a little on the top end. Any other options out there for maps that I may have missed? I'm going to start tweaking this map but thought maybe I could find one that was a closer starting point.
  2. Action
    Action New Member
    Albuquerque
    Look at the map you are currently running. If there are zeros then you are getting the same injector pulse as stock. There is also a map compare feature on the PC software. When you make changes to your base map, rename it as something else and you can compare them. I haven't seen a lot of interest in maps for a stock bike, as you've seen in your search most people use a PCIII in addition to other mods. Good luck with you search.
    Action
  3. Twin Turbo B5
    Twin Turbo B5 New Member
    Northern California
    PC3 Maps
    I'm about to pull the trigger on a K&N, PC3 including the o2 eliminator.
    Here are 10 maps from VFRD, does not seem to have any for stock exhaust but perhaps you'll be able to benefit in the future if you gut your stock cans or replace them:thumbsup:
