PC3 map for Staintune and K&N (5Gen)
Discussion in 'Mechanics Garage' started by drewboyaus, Oct 29, 2018.
  1. drewboyaus
    drewboyaus New Member
    Hi all....
    Was wondering if anyone had a PC3 map to suit a ‘98 Gen5. It’s currently fitted with a high rise Staintune and K&N filter.
    A map that is suited to 95-96 RON fuel would likely be most suited so possibly a European map...
    Thanks in advance for any assistance.
  2. Gator
    Gator Member
  3. OOTV
    OOTV Member
    If you're not satisfied with what Dynoject has to offer, many over at VFRDiscussion.com share their maps in the downloads section, although as most will tell you, having your bike properly tuned is the best method, albeit at cost. When I first got my PCV for my 6 Gen, I had the stock map and it definitely helped with the low speed stumble it had but it was by no means tuned for maximum performance, whether that was optimum power or optimum MPG.
    I did find a map over at VFRD that was better and was sufficient for my needs at the time, but since I had not disabled the PAIR valve, something you would need to do for a proper Dynotune, I never went that route.
  4. OZ VFR
    OZ VFR Member
    Old Toongabbie, Australia
    PM me with your email address and I'll send you the one I'm using now.
    It seems the best out of all I've tried, and it's not on the Dynojet site.
    drewboyaus and OOTV like this.
  5. dhinson66
    dhinson66 New Member
    Nashville, Tennessee USA
    Here are multiple maps someone on one of the forums sent me when I asked for a PC3 map for my '98 VFR with a Vance & Hines Titanium slip-on and a K&N filter. Open the Legend file to see the description of each file. For some reason I can't upload the actual .map files in the message. Send me a PM and I can try to send the maps that way. The map I used was good-much more responsive and actually a bit more gas mileage vs stock.
    David
