Partzilla Mistakes, Will Not Correct
Discussion in 'General VFR Discussions' started by Luciano, Jun 3, 2014.
  1. Luciano
    Luciano New Member
    Hey guys,
    Its been a while since I posted but I thought I should ask for opinions on a situation I'm dealing with over at partzilla.com.
    I ordered a rear rotor from the for my 2007 VFR800 ABS using their microfiche, but when I received the part, I had problems with my ABS light not turning off. Turns out, the part the sent me was for the Non-ABS model and it was missing the pulse ring used by ABS. Turns out I have to replace the pulse ring from my part, so when I figured that out, I tried to swap the ring, but the part I received would not work since it didnt have the holes for the bolts needed. I received a part for the NON ABS model even though it is listed on their site for the VFR800A.
    I contacted them about it and they seemed to agree that it was a mistake on their microfiche but when I gave them my VIN, they said I used the wrong VFR800A model, the 2AC rather than the AC model. When I explained that it didn't matter if it was the 2AC or AC model, they were both ABS and needed the ABS part, they refused to correct a mistake caused by them and one which they partially agreed was a mistake on their site.
    The part is http://www.partzilla.com/parts/detail/honda/HP-43251-MCW-D01.html still shown as used on a 2007 VFR800A.
    At this point, I've tried to explain the situation to no avail and they're using the "your bike is the AC not 2AC, you got the wrong part because you used the wrong bike model" excuse to not fix the issue.
    At this point, do you guys think I have any way of getting this fixed or am I out of luck?
    EDIT 1: Removed my email address.
    Below is the full conversation sofar.
    Ticket #123247
    Message icon Re: Re: Re: Help Returning an Item
    The VIN number I provided is irrelevant, the part needed for the 2AC model
    is the same as the AC model since they both need the ABS part for the
    VFR800A.
    On Tue, Jun 3, 2014 at 5:57 AM, Shannon <parts@partzilla.com> wrote:
    > There may be an issue with the 2AC page; however, that is not your model.
    > Based on the VIN# that you provided to me, you have VFT800A AC, not the 2AC.
    > Regards,
    > Shannon R.
    > Customer Service
    > www.Partzilla.com
    > Toll Free: 877-473-4595
    > International: 00-1-229-584-0046
    > Email: parts@partzilla.com
    > How am I doing? Email my supervisor: supervisor@outdoornetwork.com
    Last message received Date: 06/03/2014 Time: 10:46:45 AM Name: Luciano
    Message icon RE: Re: Re: Help Returning an Item
    There may be an issue with the 2AC page; however, that is not your model. Based on the VIN# that you provided to me, you have VFT800A AC, not the 2AC.
    Regards,
    Shannon R.
    Customer Service
    www.Partzilla.com
    Last message sent Date: 06/03/2014 Time: 08:57:27 AM Replied by: Shannon
    Message icon Re: Re: Help Returning an Item
    I do believe that I was looking at a VFR800A. If you look at microfiche at:
    http://www.hondapartshouse.com/oemparts/a/hon/5053f631f870021c54be7e51/rear-wheel
    http://www.dealercostparts.com/page...R_WHEEL/VFR800A-07-JPN-2AC/2Y14MCW6MCWAF1700J
    http://www.partspitstop.com/oemparts/a/hon/5053f631f870021c54be7e51/rear-wheel
    http://www.babbittsonline.com/oemparts/a/hon/5053f631f870021c54be7e51/rear-wheel
    If its the model VFR800A AC or VFR800A 2AC, they both list the correct
    part, 43251-MCW-D11.
    If you then look at your own pages for both the VFR800A AC or VFR800A 2AC:
    http://www.partzilla.com/parts/search/Honda/Motorcycle/2007/VFR800A+AC/REAR+WHEEL/parts.html
    http://www.partzilla.com/parts/search/Honda/Motorcycle/2007/VFR800A+2AC/REAR+WHEEL/parts.html
    you will find that the discrepancy rests with your 2AC page, as it lists
    both the 43251-MCW-D01 and 43251-MCW-D11 for the VFR800A.
    Regardless of the model being chosen being the AC or 2AC, they are both the
    ABS model and should correctly list the part D11 as the ONLY option, as ALL
    other parts sellers only list the D11 regardless of AC or 2AC model, as
    shown in the above competitors pages.
    With the information provided above, I believe that the error on the
    partzilla page led to this incorrect part being selected, and I believe it
    lies with Partzilla to correct.
    Please let me know what you think.
    On Mon, Jun 2, 2014 at 1:07 PM, Shannon <parts@partzilla.com> wrote:
    > Thank you. Neither of us were under the right model based on your VIN# as
    > I was looking only at the VF800A model, not yours the VF800A AC that yours
    > is. That ABS can make all the difference. Below I have listed a link to
    > your particular model and item 17, part number 43251-MCW-D11 is what you
    > should have ordered based on your VIN#.
    > Unfortunately we are unable to accept back parts that have been installed.
    > Please let me know if you have any additional questions or concerns. Thank
    > you.
    > Regards,
    > Shannon R.
    > Customer Service
    > www.Partzilla.com
    Date: 06/02/2014 Time: 06:14:36 PM Name: Luciano
    Message icon RE: Re: Help Returning an Item
    Thank you. Neither of us were under the right model based on your VIN# as I was looking only at the VF800A model, not yours the VF800A AC that yours is. That ABS can make all the difference. Below I have listed a link to your particular model and item 17, part number 43251-MCW-D11 is what you should have ordered based on your VIN#.
    Unfortunately we are unable to accept back parts that have been installed. Please let me know if you have any additional questions or concerns. Thank you.
    Regards,
    Shannon R.
    Customer Service
    www.Partzilla.com
    Date: 06/02/2014 Time: 04:07:10 PM Replied by: Shannon
    It was 2 separate emails, Vin is JH2RC46487M900185
    On Jun 2, 2014 10:18 AM, "Shannon" <parts@partzilla.com> wrote:
    > I apologize but I am not showing any picture attached. We do on occasion
    > have an issue with the pictures not coming through. It may be easiest for
    > you to enter the VIN# within the body of the message. Thank you.
    > Regards,
    > Shannon R.
    > Customer Service
    > www.Partzilla.com
    Date: 06/02/2014 Time: 01:32:19 PM Name: Luciano
    I apologize but I am not showing any picture attached. We do on occasion have an issue with the pictures not coming through. It may be easiest for you to enter the VIN# within the body of the message. Thank you.
    Regards,
    Shannon R.
    Customer Service
    www.Partzilla.com
    Date: 06/02/2014 Time: 01:18:33 PM Replied by: Shannon
    Message icon Re: Help Returning an Item
    Here is a photo.
    On Jun 2, 2014 9:11 AM, "Luciano " <lucianoxxxx email> wrote:
    > It is JH2RC46487M900185. I will send a photo shortly.
    > On Mon, Jun 2, 2014 at 8:04 AM, Shannon <parts@partzilla.com> wrote:
    >> Dear Luciano,
    >> I was able to locate your order and it does appear that you are correct.
    >> To make 100% sure of the correct part number, please provide me with your
    >> VIN# so that I can look it up in Honda's system. Thank you for your
    >> cooperation.
    >> Regards,
    >> Shannon R.
    >> Customer Service
    >> www.Partzilla.com
    Date: 06/02/2014 Time: 12:19:57 PM Name: Luciano
    > Dear Luciano,
    > cooperation.
    > Regards,
    > Shannon R.
    > Customer Service
    > www.Partzilla.com
    Date: 06/02/2014 Time: 12:19:56 PM Name: Luciano
    Message icon RE: Help Returning an Item
    Dear Luciano,
    I was able to locate your order and it does appear that you are correct. To make 100% sure of the correct part number, please provide me with your VIN# so that I can look it up in Honda's system. Thank you for your cooperation.
    Regards,
    Shannon R.
    Customer Service
    www.Partzilla.com
    Date: 06/02/2014 Time: 11:04:06 AM Replied by: Shannon
    Message icon Help Returning an Item
    Email: lucianoxxxx email
    OrderNumber: 80851497
    PartNumber: 43251-MCW-D01
    Message: I searched for the rear rotor for my VFR800A using your parts catalogue. from the 2007 Honda VFR800A page, rear wheel, I selected 43251-MCW-D01 as the rear rotor. When the part arrived and I installed it, my ABS light would not turn off. The part is incorrectly listed for the ABS VFR800A, the part is for the NON ABS VFR800 (non A version).
    Date: 06/01/2014 Time: 11:58:40 PM Name: Luciano
  2. jev.
    jev. over there
    Call them and talk to a human. Escalate it to as high as you can if you don't get anywhere with the peons. I would think that they would have no problem swapping out the wrong one. If they won't, then lesson learned and use bikebandit.com or servicehonda.com or pick another supplier. I use bikebandit constantly and haven't had a problem.
  3. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    Technically it sounds like they are correct and you ordered the part based on the incorrect model according to the VIN. If you had ordered the part for the AC rather than the 2AC would you
    have gotten the correct part? If so then you're kind of up the creek if they want to be really picky. It looks like they are just being pissy about the whole thing, when they should just own up
    to the fact their parts fiche lists the wrong part.
    IMO they should step up and replace the part since the parts fiche is incorrect, even though it's not really the parts fiche for your bike, based on the VIN. Good customer service would demand
    that they fix the error, even though strictly speaking it's not completely their fault.
    Of course all the above is based on the hope that I understood the post correctly. LOL
  4. nearfreezing
    nearfreezing New Member
    Worcester, MA
    If you ordered the part for the 2AC, then it should fit the 2AC. What motorcycle you have is irrelevant. If the part you received does not fit the 2AC due to an error in the microfiche, that's all Partzilla's fault. Keep at it, politely.
    If you do get stuck with it, I'm sure you can get at least half your money back by reselling it here. Better than nothing.
  5. BWeiss
    BWeiss Johnny Partseed
    Rancho Cordova, Ca
    If you don't get anywhere with partzilla, you can also try to take up the issue with your credit card company and get your money back.
  6. reg71
    Sikeston, MO
    I was gonna suggest just selling it on here and getting the correct part. For the cost of a rotor, you have already done more arguing with them than I would have. I'd just let them know you will no longer use their service, and that you posted your experience on one of the biggest online VFR forums on the planet. I believe we have over 20,000 users now. (Not that many are active but they don't need to know that.)
  7. Y2Kviffer
    Y2Kviffer Insider
    RALEIGH, NC
    If it's a recent transaction and you used a credit card, have your cc company stop payment...that will get someone's attention!!
    I was looking at their site a few days ago....will definetly not buy there now....
  8. Luciano
    Luciano New Member
    If I used AC rather than 2AC I would have received the correct part but only because the AC partsfiche did not have errors.
    I of course agree that it should be theirs to fix as it was their site that had an error!
  9. Luciano
    Luciano New Member
    I completely agree, if the part was correctly listed, it does not matter if its 2AC or AC, it should fit an ABS bike, but they don't seem to think so.
    If they don't fix the issue, I will probably try selling the part to recoupe some of the cost.
  10. Luciano
    Luciano New Member
    This is an interesting option.
  11. Luciano
    Luciano New Member
    The issue is escalated as Jev suggested, but if that doesn't work, I am going to post it on every moto forum known to man, even if it only has 2 users.
  12. V4toTour
    V4toTour New Member
    It shouldn't matter what bike you own. You could own a harley bagger and just bought have bought the rotor for whatever reason. If the part they sent isnt for the AC, and that's the fiche you used, you should get your money back.
  13. nearfreezing
    Worcester, MA
    Luciano - any luck?
  14. reg71
    Sikeston, MO
    I was looking for some items recently and this site came up. I will probably avoid them now just because I was a little leery of an operation this big keeping their information accurate anyway.
