Part names and numbers for parts near spark plugs???
Discussion in 'Mechanics Garage' started by SouthTexasRich, Aug 13, 2013.
  1. SouthTexasRich
    SouthTexasRich New Member
    San Antonio, TX
    OK, I need your help with some part names and numbers.
    The long rubber tube-shaped "thingy" that connects to the spark plug and then gets bolted down... what is that called?
    Also, I was looking at this online parts diagram but I failed to find the part I need.
    What I need are the screws (bolts??) that hold down the above-mentioned part, (front and rear, which are two different types). The last time I changed the plugs I noticed that these bolts are showing some wear, so I plan to replace them before they get rounded and I have a real problem...
    Any help is appreciated.
    Rich
  2. OOTV
    OOTV Member
    Look under 'Wire Harness' on the online parts link. Those long things are the coils.
    The bolts that hold them are:
    BOLT, FLANGE (6X20)
    95701-06020-08
  3. SouthTexasRich
    San Antonio, TX
    WOOT. Thank you! I was so frustrated.
