parrt throttle surging
Discussion in 'Mechanics Garage' started by tazman, Jul 10, 2010.
  1. tazman
    tazman New Member
    Anyone know of a fix for a surging 02 vfr? Just serviced, everything looked good. I seem to remember something about reprogramming to fix a problem like this.
  2. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    lot of little things people do. block off the pair valves, take out the intake flap and snorkel etc...
    i think the most important thing to do is the o2 sensor eliminators. this coupled with a power commander and good tune will make the bike perform perfectly.
  3. tazman
    tazman New Member
    Thanks I'll try those thinngs. Being in Canada we have a bit of a hard time getting some of the goodies you guys can get. I'll source the power commander and the o2 eliminators
  4. Cogswell
    Cogswell New Member
    All I did on my '08 was to install a PCIII with the Staintune map and remove the O2 sensors using the $2 resistor mod (saved the $30 buying the elim's from Dynojet). Runs as sweet as my '99 - no surging issues at all.
  5. TOE CUTTER
    Power Commander is a must......last three I bought came with 02 eliminators. Should be no need to purchase them seperatly.
  6. katat58
    katat58 New Member
    Hazen, AR
    I just blocked off the Pair valve, disconnected the O2 sensors (per this forum) and ensure your starter valves are in adjustment according to the shop manual with number 4 cylinder being the default. Mine runs smooth as slilk now.
  7. tazman
    tazman New Member
    Thanks everyone for the help
  8. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    so you good now?
