PAIR valve problem on VFR800Fi
Discussion in 'Mechanics Garage' started by lanhet, Apr 10, 2011.
  1. lanhet
    lanhet New Member
    Hi to you all!
    I am new to the site (just registered in fact) although I have been riding my 2001 VFR800Fi for 2 years now. I am located in Montréal, Canada, where the summers are short, roads look like a battlefield and car drivers are motorcyclist killers on a mission. I also own a 1988 Hawk GT, a 1985 XT600 (for urban guerilla...) and a 1969 Norton Commando S.
    I finally took the VFR out of the shed this past week, only to find I have an annoying little problem. When either the clutch or neutral switches are actuated (changing gears between 1st and second or vice versa, or pulling the clutch lever all the way in) the PAIR valve is actuated (I can hear it very distinctly). Suspecting something was wrong with the ignition safety system, I replaced the sidestand, clutch and neutral switches, unfortunately without any success. I also checked, and then replaced the dual diode unit, no luck. I am now starting to fear the ECU is responsible for the problem. Although performance is not affected at all, this is certainly a sign that something will eventually go wrong...
    Any suggestions?
    Thanks in advance and keep the rubber side down
  2. John451
    John451 Member
    Might just the Flapper Valve ? If so don't worry about it, my previous Gen 6 flapper was noisy with loud "pop" sound off idle in neutral and first my current Gen 5 quieter but have heard other Gen5s noisier.
    Flapper Noise info:
    '98 VFR800FiW to '01 VFR800Fi1 Mysterious Tapping Noise from under Fuel Tank - Honda VFR Club
    I had a Pair valve that had gummed slightly open, symtoms were poor fuel economy and sigificant backfiring on underrun in any gear, used belows ( UK VFR site ) guide with success to remove and clean them.
    Pair Valve " How To " Guide
    '98 VFR800FiW to '01 VFR800Fi1 Increase in Fuel Consumption and Loss of Power - Honda VFR Club
