Pair valve mod, air filter and starter valve synch results and question
Discussion in 'General VFR Discussions' started by deancol, Jun 10, 2016.
  1. deancol
    deancol New Member
    Dallas, TX
    Greetings all,
    Just wanted to provide a little feedback on my recent pair valve mod, air filter and starter valve synch of my 04.
    Pair Valve Mod:
    Disconnected solenoid plug
    Completely removed the pair valve (very easy to do and cleans up the area)
    Capped opening with rubber plugs and hose clamps.
    Air Filter:
    new Emgo air filter
    Starter Valve Synch:
    Not sure if I did this exactly right but I managed to get close enough readings on my carb meter.
    Other:
    I did not do the flapper mod nor did I do the snorkel removal mod.
    However, I read on one post where some had sliced a portion of the snorkel to allow more air in; I did that.
    The Result:
    A much smoother bike from 1st gear to 6th.
    Seems that there is more power in a single gear; meaning I find myself staying in a gear lower than before.
    For example, at 45mph, I would usually be in 4th but I feel (or the bike feels) more comfortable staying in 3rd.
    Concern:
    The only concern I have is that the bike idle's around 1100 and 1200 but I can no longer set the idle speed higher; its tapped out.
    Did I screw something up major in the Starter Valve synch process?
    Not sure if I should be concerned because the bike runs awesome now after these changes.
    Anyways, thanks to all members on this site for the great information. I would not have done any of this without your help.
    Dean
