Pair valve and power commander
Discussion in 'Mechanics Garage' started by duccmann, Mar 23, 2013.
  1. duccmann
    Hey guys...woke up at two am woundering when I install my PCV this next couple of days...should I re-plug my pair valve back together ???? The last thing I want to do is screw something up and start having my f1 and codes start popin up. Thanks in advance and I know I can always count on my buds here...
  2. CRFan1
    CRFan1 New Member
    Northwest Indiana
    Leave it disconnected, it will work much better that way and you would need to for a proper dyno tune anyway.
  3. duccmann
    Ride on....thanks CRFMan
  4. OOTV
    OOTV Member
    You can leave it dis-connected. The PAIR valve system will affect the exhaust output throwing off the dyno readings. It's one of those things that if it's not installed no harm, no foul. So, it looks like the PCV is going to work for you after all?
  5. duccmann
    Ya talked with them and was told the V will work on 1998-2007. All I have to do is go pick it up...its in. Now I thinkin of buying the Leo Vince SBK system while Im at it.
