"Oversteering" with my 3rd Gen
Discussion in 'Mechanics Garage' started by Make56, Sep 17, 2010.
  1. Make56
    Make56 New Member
    Finland
    Kirkkonummi
    I have bought -93 3rd gen VFR with 60 kMiles in the clock. Still it goes well and probably has many miles in front of her.
    But there is one thing which bothers me, I wonder anyone can help. The bike goes well in high speed but in cornering it tends to "oversteer" so that I have to push against not to turn too much. The feeling is the same when you have too small pressure in front tyre. I have tried different pressures but with no help.
    I have driven few other similar bikes without this feeling. Does anyone have solution of idea what is wrong? :confused:
  2. Mark 024
    Mark 024 New Member
    Sydney, Aust
    Do you mean low speed cornering, like going around a roundabout?
    It might be a case of worn or loose steering head bearings. IMO this feels like when you want to go left at a slow pace the bars want to go left and 'drop in'. Put it on the centre stand and wiggle the front to feel for any play. Hope this helps, anybody else got a suggestion?
  3. 02 VFR Rider
    02 VFR Rider New Member
    agreed ck bearings but also when was the last time the fluid in the forks have been change, that is overlooked a lot.
  4. Make56
    Make56 New Member
    Finland
    Kirkkonummi
    Yes Mark, I mean slow cornering in town and roundabouts.
    Steering head bearings has been changed by the previous owner. They were bit loose and I had the adjustment done by Honda importer garage and now there is no play there but it did not cure the problem.
    I replaced the fork seals and I'm thinking if the oil viscosity (7) was correct because the old oil was much thicker. Could it be the reason?
  5. 02 VFR Rider
    slow speed handling sucks ( well on my 6th gen ) so it is most likely just the way it is. how is it over 40mph?
    and when you did the seals did you change the fluid in the forks?? a little fuzzy on that part.
  6. tinkerinWstuff
    Check fork height in the tripple clamp. Forks moght be clamped low for heavier rider. Che
  7. tinkerinWstuff
    A heavier rider on stock suspension squats the rear of the bike too much and changes the bikes intended geometry. The bike rides like a cruiser and won't turn. The cheap fix is to drop the front in the triple clamp to restore the geometry. If the front is too low, you get the opposite of a cruiser and the bike falls into the corner. So if the previous owner was a heavy and you're a twig, the suspension could be setup wrong for you. There doesn't have to be anything wrong or broken to get your problem. Ask me how I know....
  8. Mark 024
    Mark 024 New Member
    Sydney, Aust
    Ok, so was the back squatting or the front too low when you bought yours??
  9. tinkerinWstuff
    My 3rd gen refused to turn. I constantly had a battle trying to make the thing turn and couldn't keep up with anyone in the mountains. Went to a local suspension guru and got a lesson on rake and trail. Lowered the front a half inch to get the thing to steer. Now I upgraded to a 929rear shock and I'm considering raising the front back up because she almost falls over a little too quick for my taste. We'll see.
  10. tinkerinWstuff
    So likewise, you need to make sure preload on the rear shock is not set too high for you. Sport bikes are very suspension and rider sensitive compared with other style bikes where you just adjust so the rider can reach the ground and the controls comfortably.
  11. vfrcapn
    vfrcapn Member
    Grass Valley, CA
    If the rear squats too much the bike won't turn at speed but will "flop" over at low speed. The first thing to do is set the sag front and rear properly. I'm sure there are threads here on that or Google one, sportrider.com has a nice write up. If you can't set the sag within the limits then you'll have to look at upgrading the suspension components, adjusting ride height, etc.
  12. Make56
    Make56 New Member
    Finland
    Kirkkonummi
    Thanks all, I will try to find out the right setup for the suspension.
  13. crustyrider
    crustyrider New Member
    North Country, New York
    I had a suzuki that dove into a left corner ( hard like you are saying, I had to almost pull it out of the corner) but not to the right......turned out the frame was bent a bit
  14. tinkerinWstuff
    Any updates on this?
  15. Make56
    Make56 New Member
    Finland
    Kirkkonummi
    No help this far.
    Yesterday I found out that rear tire is 10mm wider then the original (now 180/55), it may cause the problem as well.
    Anyway, I think I have to check the suspension during winter time.
  16. Mark 024
    Mark 024 New Member
    Sydney, Aust
    I read the write up on suspension setup on Sportrider.com
    It was pretty clear and easy to follow. I'm going to go through it in the next couple of weeks. Now I have a new rear tyre, chain and sprockets, head bearings checked etc.
  17. Make56
    Make56 New Member
    Finland
    Kirkkonummi
    OK, after trying different setups for the suspension, higher and lower front, harder and softer rear without any help for the issue, I finally purchased the new set Michelin Pilot Road2's and surprise - all problems gone.
    It seems that the front wheels had a flat middle and when turning there was a corner on the tire, which caused the touch point to ground to move outwards and caused the issue.
    Thanks all for the help, now I love my VFR even more!
  18. camo
    camo New Member
    The Heartland
    Glad that you have solved your problem. Besides worn tires, too narrow of a front tire or too wide of back tire can make the bike feel like that.
  19. Heatmizr
    Heatmizr New Member
    Charlotte, NC
    Good to hear!
    This is yet another example of reported handling woes miraculously SOLVED by fresh tires! To all you with handling issues, searching these forums out there, listen up! Very few bikes have loose bearings, bent frames, etc etc etc, but HALF of all bikes have tires that are worn out!!
  20. VFRnewbie
    VFRnewbie New Member
    Devon, UK
    Having fitted a fresh pair very recently, I was astonished at how much sweeter my third gen was to throw through the bends. Of course I was expecting an improvement - my old Avons were becoming just a little scary.... But just how much sharper and more positive the turn in became was a genuine suprise.
    Like yourself - I now have even more appreciation for my (scruffy, old, tired, battered.....yet) perfect VFR!
