Wasnt paying attention and overfilled the tank by a little bit. Then i noticed a wet spot under the bike. there was liquid that appeared to be dripping from one of the 3 hoses that peaked from under the bike. It was fuel. Is that normal? I ran it then stopped and no leaking. first time this has happened. then again this is the first time i overfilled the tank. Ill keep an eye out, but just wandering if the overflow goes back into the tank or not. may have been some roll off or something.
Yep normal, you will notice the small overflow port inside the tank lid. It runs down to the coolant overflow and fuel tank breather tubes.
Perfectly normal, that's why that hose is there. Kind of neat actually, if you over fill alot of older bikes you pour gas all over your tank.
