Oil for 86 VFR 750 ?
Discussion in '1st & 2nd Generation 1983-1989' started by mjrfd99, Feb 25, 2009.
  1. mjrfd99
    mjrfd99 New Member
    Jersey shore
    Sorry to start an oil thread. I'm a new owner of a mint 86 w/20k on it. Which oil do you reccomend? I use Shell rotella synthetic in my inline 4's and have been happy w/it. Those bikes got synth after a 3k break in on dino. Would you put synth in a V 4 @ 20k? Thanks from a newb
  2. supertex
    supertex New Member
    Not without changing all your seals. Those old ones tend to spring leaks. But, if you do the replacement on the seals, I think its a good idea.
  3. stewartj239
    stewartj239 Member
    Syracuse, NY
    I've run a semi-synthetic in my '86 750 for years and have had no issues at all. I also run the semi-synthetic in my '86 500 and 1000 and again, I have had no problems with leaks. I also run it in my '07. I like the semi-synthetic because it is a compromise and works well.
  4. Yonan
    Yonan New Member
    TURLOCK, CA
    I also run semi-syn(Castrol)in mine, no issues.
  5. mjrfd99
    mjrfd99 New Member
    Jersey shore
    Thanks for the info
  6. woody77
    woody77 New Member
    Palo Alto, CA
    Been using Amsoil motorcycle oil (full synth) for 2+ years and a couple thousand miles. Doesn't leak or use a drop. (22K on the clock)
  7. Rollin_Again
    Rollin_Again Member
    Duluth, GA
    I use regular Shell Rotella dino oil in both my machines.
    Regards,
    Rollin
  8. mjrfd99
    mjrfd99 New Member
    Jersey shore
    Thanks, I am grateful for the feedback. I see this is where to be to get some great info on the VFR
