MY 2006 VFR800A came with a Ohlins S46DR1S 01092-69/170 L385.If i read charts right about Ohlins spring rates i see that the spring rate is 17.32 Kg/mm @ 971lbs/inch. I am 5' 8" about 220lbs geared up.I plan on doing the triangle plate flip to lower the height. Do i need to change the spring or will it work? Thanks for any advice.
I'd either check with ohlins US or contact "kyle racing". Kyle Racing - Roadracing Motorcycles They supplied my Ohlins and are regularly in contact with Ohlins..
