OEM fairings and paint match
Discussion in 'General VFR Discussions' started by JJFlash7, Jul 5, 2013.
  1. JJFlash7
    JJFlash7 New Member
    Well, I managed to drop my VFR in an incredible embarrassing way...it involves failure to deploy the kickstand.
    Long story short, I am in for ~$800 of new fairings. The lower cowl was scratched and the "dumbo" turn signals punched through the upper fairing making a mess of that.
    So, I order new OEM fairings for a 98 VFR and installed them yesterday. When I was done the upper cowl and lower cowl have a noticeable difference in paint color. The upper cowl is a little darker red and the paint finish is not quite as good as the rest of the VFR panels. the paint appears a little "soft" with a less than a mirror smooth finish. The new lower cowl is a little less red with a hint of orange and a nice mirror smooth reflection. Both panels are genuine Honda OEM parts.
    Since these are both brand new items I don't think it is a paint fading problem.
    I can call the supplier where I bought the fairing panels but I am not hopeful.
    I think a causal observer would not notice the difference but now that I have I see it every time I look at the VFR and it drives me crazy.
    Is there more than one red paint code for 98-01 VFRs?
    Has anyone experience this with new panels?
  2. Scubalong
    Return your new fairing and try to fix your original :biggrin:
  3. tinkerinWstuff
    Would cost over $500 and the paint still wouldn't be an exact match. Honda paint is a different process than your normal prime, base, clear so without painting the whole bike it's a battle to get a match. *for the pearl colors that is.....
  4. Badbilly
    There are dozens of reasons why your red fairing panels do not "match" . This would be the case even if a panel were to be repaired and repainted. Red is the big culprit
    Try Google and "red paint fade" For more see "fugitive"
    colors, pigments ect. Red by nature is transparent as well. The primer or undercoat should be uniform for all parts to be painted. Best color for a prime coat is a 17% reflectance gray. This is a standard photo or colorimeter gray.
    Red paint is also pricy..
    Given enough time and sun, red Hondas will fade to a nice titty pink in spots.
