Odd H4 Bulb's on Our VFR's??
Discussion in 'Mechanics Garage' started by PAFirefighter11, Apr 17, 2010.
  1. PAFirefighter11
    PAFirefighter11 New Member
    Southeast PA / Brick, NJ
    My 98 seems to have an odd shaped bulb. I thought they were H4's but normal H4's don't seem to fit.. wtf.. Help? lol... Thanks.
  2. Badbilly
    Some VFRs and others have a "Honda" sized receptacle. This allows Honda to charge 2-3 times as much for a bulb as your friendly autoparts store.
    Several fixes for this including tin snips and shims in the archives.
  3. Knife
    Knife Member
    Downingtown, PA 19335
    Just bend back two of the tabs 90 degrees or cut them off and they slip right in and work perfectly. You can get H4 bulbs at an auto parts store for well less than $10.00 each. Honda wants over $30.00 last time I checked.
  4. Meatloaf
    Meatloaf New Member
    Indianapolis, IN
    BadBilly is right. 5th gens use a "modified" H4 bulb. There are several solutions to make a stock h4 bulb fit and I believe that adapters for them can be found on EBay.
  5. Badbilly
    I posted the source for the shims on another similar thread. I have misplaced the invoice. Gotta say by removing the ears on the bulbs the fit is gonna be loose. The shims are about 12 bucks. Save a couple of bucks shipping by calling in the order and have them USPS the shims rather than UPS for 5-6-7 bucks. The shims are stainless and wieigh less than a couple of sheets of typing paper. A first class stamp is all that is needed.
