Odd Clutch Activity
Discussion in 'Mechanics Garage' started by 1stCavArmyVet, May 23, 2014.
  1. 1stCavArmyVet
    1stCavArmyVet New Member
    North Port, FL
    Ok anyone else have this happen? My 01 is possessed. I noticed that alot of the time, when I pull in the clutch (I.E. Slowing to coast to a light), it will be a good 1 to 1.5 seconds before I feel it disengage. I am pretty sure it's clutch time, but wanted to make sure. I am going to flush all the fluids on the 1st so if it's a fluid issue, that should fix it.
    Also, anyone used Barnett clutch on the 01? What were your opinions of it? I would like to replace this one with a clutch that is balanced between price and my aggressive riding nature.
  2. TNRabbit
    TNRabbit New Member
    Woodford, VA
    Sounds like a sticking slave cylinder. Probably time to clean the entire clutch system out from top to bottom. You can get rebuild kits for the master & slave here for cheap; I just ordered one for my slave: http://www.v4market.com/98-VFR800_c_159.html
