o2 sensor question
Discussion in 'Mechanics Garage' started by D-rider, Jul 22, 2010.
  1. D-rider
    D-rider New Member
    Ottawa, Canada
    Does anyone here know what wire to the o2 sensor would be referred to as the "signal" wire. There are 2 white wires, 1 black wire, and 1 grey wire...any help would be appriciated.
  2. Scott_Lilliott
    Scott_Lilliott New Member
    Sweden
    Massachusetts
    After studying the wiring diagram for an '02 VFR (non-ABS, but I doubt that matters),
    I would SWAG that the white wire is the signal wire. I say that because each white one from the sensor(s) traces directly back to the ECM to a discreet pin. The gray wires jumper between each other.
  3. 02 VFR Rider
    02 VFR Rider New Member
    you have four wires, 2 white, one grey and one black. the black is the one you want
  4. Scott_Lilliott
    Sweden
    Massachusetts
    Oh - I see that now, yes you're correct, thanks.
