O2 Eliminator installed. Get PGM-FI error message 23 and 24
Discussion in 'Mechanics Garage' started by Betelgeuse, Sep 1, 2008.
  1. Betelgeuse
    Betelgeuse New Member
    Oslo, Norway
    Hi
    I just installed my Power Commander III USB and the supplied O2 Eliminators I bought from MorePowerRacing.
    The install was a breeze, even for me.
    I followed the instructions for the PCIII and disconnected the battery while installing. And of course remembered to connect the last wire to the negative pole on the battery.
    I removed the fairing on the left side, and located the O2 sensor connectors.
    The supplied eliminators was connected to the male contact (the one nearest the back of the bike). There really wasn't any other way...
    When I start the bike, I get an PGM-FI error light that is blinking. I spells out error 23 and 24, and according to the service manual, it refers to the "No. 1 and No. 2 O2 Sensor Heater".
    Why is this happening? Have I done anything wrong, or am I missing some parts?
    Please help! I would really like to use my bike to work tomorrow.
    Can I still drive it without risking anything?
    I would like to humbly suggest that you contact Dynojet Technical support via email or telephone.....
    Part 1:
    Dynojet Research is aware that there are several U.S. based internet companies improperly (and sometimes illegally) selling and shipping our products to customers outside of the United States.
    Customers outside of the U.S. purchasing items from companies within the U.S. should be aware of the following:
    1) No warranty/repair support will be given by our official non U.S. distributors for products that we not properly imported by them. For products sold outside of the U.S. the warranty is activated by the Official Dynojet Distributor and processed through them. Products purchased from the U.S. and shipped to outside countries do not have a warranty of any kind if not purchased through an official distributor or one of their dealers.
    2) No technical support (via phone or email) will be given by our non U.S. distributors for products that were not properly imported by them. If you should require technical support please contact Dynojet Research Inc. (USA) via email (tech@powercommander.com) or telephone +1 702 399 1423 during normal business hours 8 am-5 pm (GMT -8), Monday through Friday.
    3) Missing or damaged items. If you have purchased and receive a product that is damaged or is missing items from a U.S. company you will need to contact them directly to resolve the situation. Dynojet takes no responsibility for missing or damaged items that were sold through non official channels.
    Dynojet Research appreciates your business. However, assistance from our Official Dynojet Distributors is only available due to their efforts and expense supporting our product line.
    It is unreasonable to believe these facilities would exist if products were not purchased from them or their dealers, but instead imported from unofficial sources. As you are making the choice of where to purchase our products please keep the above information in mind.
    The Management
    Part 2
    Due to a compilation error in the production of a few CDs included in Power Commander product packages, the PCIIIUSB software may be missing. This omission occurred between July 3rd and July 12th.
    This software can be downloaded for free from the downloads page of the Power Commander website. We apologize for any inconvenience this may cause our customers.
    Regards,
    The Management
  3. Betelgeuse
    Oslo, Norway
    Thank you for your advice.
    I have contacted tech support at Power Commander today.
    I took the bike out for a test drive, and it seems the PCIII is working. The throttle response is much smoother, but the enginge runs alot richer. I can tell by the smell from the exhaust, and the fact that the engine temp is lower than usual (and the exhaust temp is higher)
    I don't know is this will cause any major problems, but I rode to work today, a 10 minute drive, and will wait for an answer from the support team before I take any longer trips.
  4. Wabbit1961
    Wabbit1961 New Member
    Hudson, Florida
    NorcalBoy...
    What if you only want to install the O2 sensor Eliminators and not install the PCIII? I just want to get rid of the surge, and members here say it works. Is it going to cause my onboard computer to give error messages if I do this? None of the members here ever mentioned any error messages after doing this mod. Just curious.
    I don't want a PCIII since I do not plan to upgrade my stock exhaust system, other than replacing the air filter with a K&N filter kit.
    I have asked my mechanic to also make sure he adjusts the mix (lean it or enrichen it) if it needs such with the K&N filter and the O2 Eliminators. He's of the opinion that it won't make that great a difference in the way the bike runs and said it probably won't need to be messed with. Do you recommend any remapping for my 2006 VFR with the maps on the PC webpage?
    I was planning on having my mechanic install them on my next service (valve adjust, air filter replaced, brakes n fluid, radiator flush and replace, oil and filter change, etc...
