Nut Question!
Discussion in 'General VFR Discussions' started by i700plus, Feb 26, 2009.
  1. i700plus
    i700plus New Member
    I'm buying some parts for my viffer. Its a 1998 Vfr800. I'm looking for some replacement black rubber nuts that have the threads in them. I found them on Service honda (NUT (5MM) 90111-KW3-003) however they look different than the ones that came with the bike. The ones i have are pretty much flat and round. They pop into place and sit pretty tight in the lower fairing pieces. The ones I'm looking at seem to look very different... Like this...
    and my old ones look almost flat... Will these still work?
    Thanks!
  2. 02 VFR Rider
    02 VFR Rider New Member
    They will compress when you install them, so no problem.
    Thanks for the number I need some myself.
  3. reg71
    Sikeston, MO
    for real? they compress that much? I had no idea. I should replace just about all those myself. Mine are a sad lot!
  4. nvoges
    nvoges New Member
    Columbus, OH
    hmmm...thanks for the part#, I'll be ordering a few myself
  5. Craig in Alabama
    Craig in Alabama New Member
    Madison, AL
    Wellnuts
    You can also find Wellnuts at Lowes and most real hardware stores. Much less expensive than factory prices, although selection and sizes vary from place to place.
    Craig :smile:
  6. squirrelman
    HOW 'bout them nuts????
    recently found this inside a VFR muffler!!!!
    this is all too real!
