Not the Real '89 VFR -a mild custom
Discussion in 'General VFR Discussions' started by Skipper11, Feb 4, 2025.
  1. Skipper11
    Skipper11 New Member
    Brisbane
    My project bike, or one of them - an Australian original supplied VFR 750F that I have been playing about with for too long. Seems there are more jobs than you can poke a stick at when you retire and the Vfr is no exception.
    Started about 5 or was that 6 years ago, having just finished restoring a Kawasaki H1, and knowing it would not be the right bike (for me anyway) to use as a Club "regular rider" so asked my son to keep an eye out for a suitable Japanese bike. A short while later he found a Jap import '86 VFR 750 in pearl white - very tidy, low Kms but with a seized motor due to water ingress. I pulled the engine down but found serious pitting in two cylinders.
    What to do? long story short, he found another - an'89 model with bad damage to the fairings but a "runner" if one can call great clouds of smoke by such description.
    Undetered (or just plain silly) I bought it, put a flushing additive in the oil and 10 minuted later cleared her lungs.
    Subsequently I did give her a much-needed set of valve guide seals as they were hard and cracked so hope now not to need more attention in that department.
    Fools need help, so I went to YouTube to learn how to plastic weld. Instead, I found some very helpfull information about chemical solvent repairs using MEK -look it up - it works and does a great job with a little practice. The net result is all fairing panels fully repiraired now, all paint was removed inside and out, and they are in 2 pack primer awaiting the color.
    My choice from the outset was the USA release Red, White and Blue color scheme as used on the Interceptor.
    Originally to go on the '86 bike - but now transposed onto the '89, which has proved just a tad more complicated, but we can do anything - right?
    The larger air vents on the side pane encroach on the decal space and since I saw the option to add a large Honda decal into this area to great effect, I now need to resize. The Interceptor name was not released by Honda into Australia and add some other mods I have done to the appearance; I have chosen to replace the name with another. I came up with the name "Clubman", since my intention is to use the machine for Club rides, and it provides a little calming influence for those who want to nit-pick the detail and originality of the color scheme and design.
    I shall endevour to attach a computer-generated picture of my machine since it is as yet, unpainted and has no decals applied. Note the tail box with the lower section painted blue to line up with the seat which I shortened (and removed the foot pegs) The "lid" on the tail box is hinged at the front and opens by the old release mechanism for the seat, which makes it lockable. A spring setup pops the back of the lid when the key is turned. The box I made from fibreglass and it fits neatly over the upper part of the original tail section and taillight assembly.
    The front indicator lenses are those used on the Japanese domestic release machines, looks much cleaner and have a secondary lamp filiment for park lights. Just took me lots of time to carefully cut and file the holes since the lenses are fitted from behind the fairing.
    There are other, lesser mods, and like all such bikes, there will probably be more as time goes by :)
    Looking forward to seeing updates. I like the concept.
  3. Skipper11
    Brisbane
    A couple of shots of the fibreglass tail box. In primer, has been sanded and needs a second coat inside to tidy up.
    The hole in the front (lower down on the side) connects with a mounting point on the original seat frame via a short extention, and is held by a stepped screw so as to give a large wear surface in the fibreglass. A second mounting point can be seen by the smaller holes on the inside floor of the box. These points are replicated for both sides. The large "see through" hole will be recognised by Vfr owners as the existing mounting points for the factory tail piece, which remains in place. I have chsen not to bother covering these holes since nothing can fit past bigger than and ant's dick anyway. In the event that I ride into a river, it will provide a drain point to let the water out and keep my lunch dry. :) On the matter of water tightness around the lid, I have made provision for a rubber seal aross the front (note the step down the side in the front seal area.) The sides themselves are protected by the overlap in the lid, while across the back any water can drain freely into the latch area and out down the sides. I have a son who was critical of my idea to build my own box but even he has backed off now, ageeing that it should keep the contents dry. The original seat latch was used, with only the need to make a longer cable and add a couple of springs to pop the lid when the key is turned. Thus, clean lines with no hinges, handles or locking mechanism showing. IMG_3935.jpg IMG_3937.jpg
    mello dude and Captain 80s like this.
    Very cool. So is the passenger portion of the seat shortened and/or narrowed to gain access to the rear sub-frame mounts? How is the seat secured?
    Sorry, maybe it's obvious, but I'm at the end of my work day and my brain and eyes are tired.
  5. mello dude
    Romania
    Wow, that tail box is pretty freaking cool!:thumbs:
  6. Skipper11
    Brisbane
    My bad, I should have explained, yes - seat shortened to just behind the hooks on the seat frame. At this point there are two by 8mm tapped threads in the bike sub-frame directly below what remains of the plastic seat base. I simply drilled holes on the seat base to match these bolt holes, trimmed out the back of the seat to make space to secure the bolts into the frame and applied two 8mm bolts. The re-upholstered seat cover was custom made to suit. (Interesting - these two bolt holes were never used, but they suited my job perfectly?
  7. Skipper11
    Brisbane
    IMG_3940.jpg Sorry, not real good at this - here is the photo just taken - says a thousand words
    mello dude likes this.
    Cool!!!
  9. Skipper11
    Brisbane
    You can also see in the photo howI attached those stepped screws in the front left / right side of the tail box to the back of the seat frame
    The screws I used were a standard fitment on some model Honda, just can't remember which one?
    I machined up a solid brass block and drilled /tappped it to suit, getting a good solid connection that is locked in place
