not starting???? Can you figure it out???
Discussion in 'Mechanics Garage' started by gibby14, Apr 26, 2006.
  1. gibby14
    gibby14 New Member
    bike: 86 vfr 1000
    problem: not starting only one exhaust pipe is hot
    when i try to turn this thing over im only getting enough to keep up with the starter? after trying different amounts of throttle and starter fluid i found that i had only one exhaust pipe getting hot!!! so i am missing on all of the others! how do i fix this i'm guessing the timing is off some where? i dont know much about the bike so i am here to listen and learn!
    please help!
    other info
    yes i am getting spark to each plug and
    the carbs seem to be working just fine and the bike
    has new plugs and battery
  2. brian_06328
    brian_06328 New Member
    Oregon
    Since you've just changed spark plugs, I would check to make sure that the plug wires are on the right plugs for the firing order. Also should check compression. If you are getting fuel, compression and spark, the motor will run (provided th timing's right)
