non starter fi light on
Discussion in 'Mechanics Garage' started by lil3600, Mar 22, 2009.
  1. lil3600
    lil3600 New Member
    hello lads..first post to this group ,have also posted this question on another site and have recieved some feed back...thought i could pick some more brains.. only had bike a day or 2..decided to remove undertray,and paint around...seat frame exhaust...put bike back together ..now ,wont start...
    have charged battery..tun on ignition fi lihgt comes on....stays on...no whine type noise from pump..engine turns..turn off kill switch engnine will not turn..
    am i to assume if kill switch works,then the switch is not at fault? everything was fine until i took out and put back the seat/undertray.
    no manual at mo,so identifing the ralays are difficult
    i am thinking i have desturbed some thing..or maybe the fault was waiting to happen sods law......
    i hope ing........really....... that because the pump doesnt whine there is a simple answer..... how may i test if the pump is working...
    getting dissapointed now.........nice bike though when it went......thanks....mark...
  2. dizzy
    dizzy New Member
    MN
    You didn't ID the exact model. Check your fuses. Check your work. Do you have and know how to use a multimeter?
  3. lil3600
    lil3600 New Member
    sorted proplem....with the aid of a manual...identified the relays etc,,,
    finished with ..checking the engine stop relay... found corroded broken wire at base of relay...
    thanks for input.....by the way vfr800 fi....2000 ..cheers lads....
