no power
Discussion in 'Mechanics Garage' started by just1fvr, Aug 28, 2011.
  1. just1fvr
    just1fvr New Member
    Evansville, IN
    i literally have no power going to my bike ive looked at my fuses next to my cluster gauges and checked my battery and it still has power so im wondering if my 4th gen (94-97) has some fuses in the tail part of my bike, ive tried looking for them but to no luck :crazy:. if someone could help me out that would be fantastic.
    thanks in advance for the help
    Joey
  2. FoothillRyder
    FoothillRyder New Member
    Sierra Foothills
    a few more details about the symptom might get you some answers. What exactly do you mean by 'no power going to your bike', 'my battery... still has power'?
    Help us understand and we'll help you fix it. It's probably something simple (and yes, there's a 'master' fuse).
  3. matt1986vf500f
    matt1986vf500f New Member
    Lula, Georgia, United States
    So does the battery have more than 12 volts when you turn the key to the on position does the lights come on or anything? When you hit the starter button does the bike turn over?
  4. just1fvr
    just1fvr New Member
    Evansville, IN
    i hooked up a volt meter and it showed that it still had power in it, but when i turn the key to the open position nothing turns on. i have no lights the clock isnt on, the bike doesnt turn over nothing.
  5. matt1986vf500f
    Trace your positive battery cable to your fuse holder and check it .
  6. just1fvr
    just1fvr New Member
    Evansville, IN
    at this point im willing to try anything. thanks matt
  7. kennybobby
    kennybobby New Member
    Main Fuse
    You probably already found it, but there is a main fuse right in front of the battery.
  8. FoothillRyder
    Sierra Foothills
    Thanks to kb for posting that. Just a word of caution - do NOT use a 'visual inspection' to check that main fuse. It can look just fine and be toast. Been there, done that.
  9. squirrelman
    Loose battery terminal or loose or corroded main ground wire ??
  10. TOE CUTTER
    Four pin plug on top of relay is my first place to look. Heat damage and melting is more than common.
