You should have 12v on at least one of the Fuse small test points on top of the fuse, and power on both Test points if the Fuse is good, with Ignition to ON. If you are not seeing any 12v at the Fuse with Ignition to On, you'll need to follow the Blue/Orange wire back to the Ignition switch. Check this voltage at the switch on the Blue/Orange wire. You could have either a faulty Ignition Switch, bad connection through the Ignition Switch connector or broken wire somewhere between the Ignition Switch and Fuse Box. Do you have a wiring diagram of your bike? See attached for Ignition Switch and Fuse Box.
